$135,000 Blu-ray Player
From the article, the features that you don't find in normal Blu-Ray players are:
1. precision spring-loaded legs
To prevent them from skipping? Do Blu-Ray players ever skip?
2. a completely isolated power supply
Isolated from what?
3. Goldmund Magnetic Damping
What does magnetics have to do with an optical reader?
Since they're digital, how does a $135,000 Blu-Ray player reproduce sound or video better than a $135 Blu-Ray player?
1 & 3: to keep the disc from vibrating, thus reducing jitter. Usually jitter is not consciously audible (as stated in that article) but it is present constantly with optical discs. Less jitter = better sound (and it is measurable).
2: isolated from the rest of the circuitry to reduce EMI (and possibly RFI). It's also probably isolated from the chassis to reduce vibration from the transformer (their site wasn't specific about that but I figure if they're going to these lengths...).
This is all fine and dandy, but if you took the DAC out of this and put it in a 'normal' chassis would it sound any different? Probably not to a noticeable extent, but I bet it would reduce listener fatigue (albeit probably by a very small amount). As for the claims of this giving you a better picture, I'm highly skeptical.
Worth the money? Hell no! Not even if I had $100M in the bank. These really aren't meant to be sold anyway as they are a reference design (they're only making 50 of them).
Anyone willing to spend $135k on a "reference" BluRay player definitely deserves to be deprived of their money. For those not in-the-know "reference" quality hardware is intended for media production, but the term is often used to sell snake oil to rich people.
Since the video and audio data on a BluRay disc is digital in nature, there is pretty much no loss in transport. Anyone who is a serious A/V enthusiast won't be using the built-in D/A converters in this so-called "reference" BluRay player, they would instead be using the digital outputs ala S/PDIF/TOSLINK, or perhaps AES/EBU or MADI if they are really into their gear. The actual D/A conversion process would be handled through an outboard surround receiver, or the video DAC in your TV. In other words, a person would get the exact same quality with using a reference display and reference surround system on a PS3, as they would get with this "reference" BluRay player.
Honestly, without software features, this device does absolutely nothing your garden variety PS3 doesn't already do. In fact, the PS3 trumps this piece of shit with all of its extended functionality.
135,000 eh?
Could by a house in where I used to live - Plano, TX. (not anymore, though).
I meant to type 'buy', but there is no edit function...
(silly 33 second wait time... is that for team 33, or just arbitrary?)
Most DVD, and pretty much all BluRay players have a small amount of memory onboard to perform buffering. Jitter is eliminated as a result.
Early CD players did not have any sort of caching mechanism, thus jitter was noticable between a consumer device, and a reference quality system.
Furthermore, they do not call this a "reference" system because it's a reference design as we know it from the PC world. In the A/V universe, when something is "reference" quality, it is suitable for A/V production work. A reference system is a calibrated system which does not provide "coloration" of the sound or video. Reference grade speakers have a linear response, and do not add bass, treble, or midrange. A reference grade display is intended to provide WYSIWYG results when film, graphics, or video is sent to print.
Because the output of a BluRay player is typically 100% digital with no loss or jitter, they are inherently a reference grade product.
Wouldn't all digital players have the same output?
(quality of the output video card depending).
If the connection between the player and TV is digital, then yes.. Pretty much correct. BluRay has analog outputs in the form of component video, but if you have HDMI, you may as well use it. Once the method of transport for A/V data goes digital, loss and jitter are not a concern.
I'm going to have to disagree here. Jitter has not been eliminated. Yes, it's been improved to a great degree but it is still present. Even if a blu-ray was copied over to say a solid state or flash drive, jitter would still be present (although obviously for different reasons than media vibration).
Im all for people spending big money on stuff but 135k for that? Cmon now...they made that shit up.
For 135k it should should have a built in fleshlight for the "family" blu-rays.
considering it plays SACD's im going to guess theres an oppo BR player in there... thats the only player (besides certain PS3's) that im aware of that plays both BR disks and SACDs
I wonder if this $135k player supports all the formats that Oppo's player does, including DVD-A and various digital files.
Will it blend?
I'd pay to see someone blend one of these. More accurately, I'd pay to see the reaction on the face of people who would consider buying one of these when someone blends one.
I just don't get this stuff. None of this crap ever does better-than-odds in blind tests.
http://www.blu-raydisc.com/Assets/Downloadablefile/BD-ROMwhitepaper20070308-15270.pdf See the part about jitter? They have measurements. You can't measure something that doesn't exist.
It exists but either a player is so hrrible that the picture/audio will be corrupted terribly or it wont be an issue at all. For a digital system you have two scenarios: bit read write or bit read wrong. The latter is usually corrected through the copious amounts of error correction information on the disc. If it wasnt a good player (4x+) should have plenty of time to go back and read again.
If that fails you will get obviously garbled sound and video. Inverted colors, hitching that kind of thing. It wont make things fuzzy or flat.
For digital, if there isnt any scaling or sampling done, as said earlier, everything is inherently reference. Only the DACs (ie amp and display) can screw it up and they arent in the player.
My money is on that abomination just being a fancy shell for a Liteon or something.
Items such as these are merely status symbols. There's not much "gettin" to them. It's like a Rolls Royce, there are other cars more comfortable, there are other cars faster, moreover you can't really own a Rolls Royce and drive it yourself to be taken seriously. There is a point when people have so much money they don't know what to do with it, hence they rely on things like this to symbolize their status.
I certainly hope these things won't crap out in a similar timeframe as a PS3 (typical 3-5 years optimal performance), at 135K it better run for 200 years or something...
$135,000 bluray player and they put a cheap ass readout screen on it.
I was about to say the same thing... lol... for that much money it'd better have an OLED multi-touch-screen display with an amazing resolution... but they put a crappy LED readout on it. But wait, it's blue! That's high tech! :p
You guys just don't understand the quality of true craftsmanship.
What makes this unit better than the average run of the mill BD player is this simple fact. Average BD players are only manufactured through a speedy child sweat shop process that lacks much quality assurance where this BD Player has the sweat of a thousand little Chinese children behind each square inch of it's being...
Obviously you guys just aren't sophisticated enough to see true quality even when it is right in front of your very own eyes!
This player would be a hot deal if it also played HD DVD. But since it doesn't support that format, $135k is a rip off. :p
rofl. $135,000 worth of build quality? You have to be joking. I'll bet the laser diode still has an MTBF of 5-7 years.
This player does nothing above and beyond stroking the ego of the ultra wealthy, self-indulgent douchebag dumb enough to buy it. They took steel billets, threw them into a CNC, and used the product of that to create a hulking chassis for a run-of-the-mill BluRay player. Is that *really* worth $150k? No.. It looks like about $600 in metal stock, a few simple lathe operations, and a few mill ops.
That went right over your head apparently.
True true...
While I maintain that $135,000 is quite excessive, charging 5K for a bluray player that has hand picked capacitors may be viable. If vacuum tubes and all the shabam that comes in high end audiophile stuff difference may make a difference on the audio side of things, that is if you're outputting via analog...
But HDMI output of a Bluray is just that... Digital... It's then up to the TV to represent what's going on... Furthermore, if the audio is outputted through the HDMI, the price is even more "WTF" worthy...
Come to think about it, those PS3 comments are making more and more sense!!! I mean I paid $1500 for a CD player in the late 90s that was constructed with an all aluminum chassis and had a 1 bit 256x oversampling DA converter. The loading tray and other mechanism looked like they were made in a machine shop. But alas, I have resorted to my iPOD for my music listening needs now. Let that be a lesson to you all...
If it comes on sale for 99% off, then at $1,350, it *might* be a good deal. :D
Still more expensive then first gen Blu-Ray players...
Seriously... one could just dump all this into a passive case, and get a HTPC instead of this.
