1333MHz FSB question
isma
Hi,
I noticed that the new 600 series chipset from nVidia will support 1333MHZ fsb.
I wonder if it's worth alone buying a mobo that support the upcoming 1333MHz new cpu that Intel will put out later this year.
Is it a big increase in performance over a 1066MHz fsb ?
Right now I want to buy a E6400 and upgrade to a high-end cpu next year. So if it's worth it I will skipped over the 1066MHz cpu and buy a 1333MHz cpu instead next year.
Thanks for your help.
I don't understand what you're saying. The E6400 is a 1066mhz FSB chip, so you wouldn't be skipping over 1066mhz. Anyway, sure, it might be worth it to buy a 1333mhz board. I'm not so sure that the current boards out there from Intel (965/975) aren't going to support 1333mhz FSB yet seeing as they can do 1600-2000mhz with OCing. I don't believe the performance increase is going to be dramatic at all.
The Gigabyte p965: DS3, DQ6, DS4 all have support for the new 1333FSB Much cheaper and maybe more reliable then a nvidia board.
does the asus p5w dh deluxe have support for 1333mhz too? gigabyte is kickin ass
yes, and pigs maybe fly.
I hope you aren't responding to my post because http://www.gigabyte.com.tw/Support/Motherboard/BIOS_Model.aspx?ClassValue=Motherboard&ProductID=2295&ProductName=GA-965P-DQ6
They didn't support the 1333 FSB until the new Bios' for these motherboards.
Not that I'm aware, its plausible but i also see them not doing it for profit reasons, so people will get new motherboards possibly. Another factor is that all those motherboards would have to be able tto clock at 1333FSB.
Gigabyte has a history of near shady ties with marketing and system specs.
I wouldn't trust their promises too much as I was once fooled into buying the GA-SINXP1394 AT800 motherboard with promise of 'HT support' and support for 800FSB.
Well what do you know, the thing would not boot up on 800FSB which was my only available hardware at the time. Even today 800FSB CPU's are listed in GA-SINXP compatability list, just with conspiquous test N/A label on it giving a false impression it works in 800FSB just not tested. The only really supported HT CPU was the 3.06Ghz Northwood @ 533 bus.
That was the last time I bought Gigabyte, the last thing I need is buying hardware that is nothing but marketing jargon.
I've just bought an Asus P5N-E SLI nVidia 650i board & that was cheaper than I could buy a 965P-S3 for here in the UK.
Just because a motherboard can reach a 1333MHz FSB, do not be fooled into thinking that the boards out now will in fact support 1333MHz FSB CPUs. The fact is, there could be design changes in those new CPUs that create compatibility issues.
Supposedly they designed the nForce 600 series to be compatible with those future CPUs, but there is no telling if this is true or not. Those boards or north bridge chips alone may simply do 1333MHz FSB on today's chips and not tomorrows. Who can know until they get samples of these CPUs in hand?
There have been far too many times where these types of situations have come up and people have been screwed thinking they had bought motherboards that would work with tomorrows CPUs. Don't forget about the Celeron socket 370 that wouldn't work with Pentium III Coppermine CPUs, or the 800MHz FSB boards that couldn't use Prescott socket 478 CPUs. Lets not forget that older 925XE chipset boards can't work with Core 2 Duos and so on. Hell even many i975x boards don't work with those CPUs because of voltage design differences in the boards. We just don't know at this point. Anything is possible.
I'm using a Gigabyte 875P right now and its running like a champ. And i agree with Dan, if a product hasn't been empirically proven then who knows it if will work. But it may be worth a shot! :)
What does supporting a 1333FSB mean? Is it just that the FSB can be clocked to 333MHz? If so, all current enthusiast motherboards from all major manufacturers can do this regardless of chipset... you can easily increase the FSB to 333 on any of them!
Which is why, hopefully, you'll just be able to get a bios update for your motherboard and be good to go. Voltage regulation is a different story though.
Essentially that is what it means. That does not mean that new 1333MHz FSB Core 2 Duo, Quadro and Extreme Edition processors will work on motherboards produced today. Additionally, the Intel chipset based boards produced today make no such claim. NVIDIA makes that claim with their newer 600 series nForce chipsets, but we don't really know at this point if that will be true. Intel could change the voltage design of the newer CPUs between now and then. We can't really know for sure until the processors are released.
You also can't get ALL P965 Express or all i975x chipset based boards to do 333MHz FSB speeds. The ECS PX1 Extreme won't always do it.
I predict that Intel will release a new chipset/chipsets which may or may not be that different from the current P965 Express/i975x chipsets out today. That means another round of new motherboards. I don't know if you will be able to get away with running the new processors on the boards we have now, but if we can, Intel won't support it as the chipsets they produce today do not support 1333MHz FSB.
On the other hand the nForce 600 series may in fact support it. NVIDIA claims it will but I really don't know.
