3dmark06? your cpu plays a HUGE role in your score. next time give more info so people wont have to ask basic questions.Is it decent on
705/1010/1670
Evga 8600GTS SLI?
Should it be higher or is it fine the way it is?
yeah 8600gts in SLI is still weaker than even a modern single midrange card.Seems a bit high as I understood the 8600's were underpowered. And two of them in SLI would still be rather weak compared to one decent GPU like the 8800GTX, which would score around 14k+.
So that's pretty good, although you're probably using WinXP. But I doubt it'll be as good in real gaming though...
reading comprehension? he meant underpowered as in WEAK. he made that perfectly clear and I even followed that up by quoting him and agreeing that they are weak.Yes, I'm on Windows XP Pro 32bit.
Underpowered? Why would they be underpowered? They're getting power from the PSU since they're connected by PCI-E connectors.
That is about right. Happy?
3DMARK is dead.
Nobody cares but the hippies at Futuremark/You Gamers.
3DMARK died with Mad Onion.
If people don't like 3DMark and Vantage then what are they using instead of those?
