Wizardhawk
- Apr 11, 2005
Gaming mostly, online college work, etc.
$1150-1300 anywhere in that range.
3) Where do you live?
Florida
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything, complete build. Have no parts.
N/A
6) Will you be overclocking?
Probably not unless it's easy to do.
Was looking at a 21.5" on newegg for a pretty good price, don't want a 23-24", they are too big for me I think.
Within the next week or so unless there is a good reason to wait a little while (no 3 month waits tho)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Nothing in particular
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
No, will be getting 64bit, probably windows 7.
Just got a nice little chunk of change, so going to build myself a gaming pc. That way me and my brother don't have to argue over play time
. Don't really want the total after shipping and tax to go over $1300, and if I can keep it closer to $1200 even better. Will also need to buy a desk, chair, keyboard and mouse, so I can't put together the awesome pc that I'd love, but o well.
I can't figure out how to change the name into a link to the item as well, so please bear with me.
These are some of the pieces I was considering, altho I haven't done too much hardcore reading on what is better and why:
Monitor: Asus MS226H - $180, got good reviews on newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236071
Case: Anything that's less than $100
Motherboard: This is one of the pieces I don't know anything about what makes them good or not.
CPU: i7 920 bloomfield 2.66 - $290
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
Ram: corsair XMS3 6GB - $175
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145286
Power Supply: Corsair CMPSU 650TX - $100
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Hard drive: Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM - $90
This says it's a bare drive, I have no idea what that means.
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Video card: Radeon HD 5850 or 5830 - $320/$250
Any recommendations on this would be nice.
OS: Windows 7 home premium 64bit - $105
Total: About $1260 + motherboard + case for the 5850
$1190 + motherboard + case for the 5830
Puts me a tad over budget, but if it's really worth it to go slightly over then I can. Any tips on where I can cut a few bucks, a good mobo and a good case would be great.
Thanks in advance for the help.
Florida
N/A
