$1200 Computer Build
richtea
Mostly programming and gaming with the odd bit of Photoshop.
$1200 (Shipping Included)
3) Where do you live?
England
CPU, CPU Cooler, Motherboard, RAM, Video Card, Power Supply, Case, Monitors (Not to be included in the Budget)
OCZ Vertex 2E 120GB SSD
6) Will you be overclocking?
Yes, if easily done.
Plan on getting two Dell U2412M's (Not part of budget)
End of this week.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
Don't require advanced features, would be nice to have SATA 6GB's though and Crossfire support for future. Also I would like the motherboard not to have integrated graphics if possible.
Yes, Legal copy of Windows 7 64 Bit.
CURRENT BUILD LIST
Motherboard: Gigabyte GA-Z68X-UD4-B3, Intel Z68 Express, S 1155, DDR3 2133, SATA 6Gb/s, RAID, ATX, USB 3
CPU: Intel Core i5 2500K Unlocked, S1155, Sandy Bridge, Quad Core, 3.3GHz, GPU 850Mhz, 6MB Cache, 95W OEM
Memory: 8GB (2x4GB) Corsair DDR3 Vengeance Jet Black, PC3-12800 (1600), Non-ECC, CAS 9-9-9-24, XMP, 1.50V
Graphics: MSI HD 6870 HAWK AMD Radeon Graphics Card with Twin Frozr III fan - 1GB
SSD Drive: Vertex 2E 120GB
CPU Cooler: Be Quiet! Dark Rock Advanced BK014 CPU Cooler LGA775/1155/1156/1366/AM2/AM2+/ AM3/754/940
Power Supply: 600W PSU, Coolermaster Silent Pro M AMBAD3, Modular, 83%Eff', 80 PLUS Bronze, SLI/CrossFire, EPS 12V, Quiet Fan, ATX
Case: Fractal Design Define R3, Black Pearl, Mid Tower Case w/o PSU
DVD Drive: Samsung WriteMaster SH-S222AB/BEBE 22x DVD±R, 12x DVD±R, DVD+RW x8/-RW x6, SATA, Black, OEM
Since all you want is Crossfire support and SATA 6.0Gb/s, you should be fine with either of these motherboards:
$130 - MSI P67A-G43 Intel P67 ATX Motherboard
$133 - MSI P67A-G45 Intel P67 ATX Motherboard
RAM wise, more than likely that Corsair RAM is overpriced. Do note that there is little to no real world difference between DDR3 1600 and DDR3 1333 RAM in apps and games. So go for the cheapest 8GB set of DDR3 1333 RAM rated at 1.5V you can find and you should be set. Corsair or G.Skill are good choices.
GPU wise, assuming that the UK and US have similar prices, that MSI card is also overpriced since it's right in the price range of the faster GTX 560 and occasionally GTX 560 Ti. So look at those cards instead.
PSU wise, again assuming that the UK and US have similar prices, that PSU is more than likely overpriced. It's a good PSU but it's often overpriced here in the U.S. So go for the Corsair 650TX V2 or Corsair 650HX if you want modular.
Of all the parts listed, the SSD is probably the weakest. Granted you are reusing it but have to let you know that SSD is probably one of the worst choices possible for a SSD now. If you were buying brand new, I would have recommended the faster, more reliable, more stable, and better supported Intel 510 series or Crucial m4 series SSDs. Hell I would have recommended the older Intel 320 series and Crucial C300 series over that OCZ SSD.
Thanks for your feedback and advice.
Is the SSD really that bad? When I purchased it a year ago, it was apparently the best value SSD on the market.
The cost of the MSI card in England is £140, which is roughly $230. Do you consider that overpriced?
I am wanting to use a modular PSU for this build and the Corsair 650HX you suggested puts a deeper hole in my pocket than the CoolerMaster one. £67.16 vs £91.98. Do you have any thoughts on Antec PSU's? Specifically this one: http://www.antec.com/Believe_it/product.php?id=MTc1OQ==
Unfortunately we didn't know what we knew now. Ples you're one of the lucky ones if your SSD has survived this long. Simply put, when OCZ switched to a different process, they lowered the performance of that SSD by quite a large margin. Unfortunately, that OCZ's performance wasn't all that great to begin with as it was shown in real world tests that its real world performance was far far below what the stated specs said. Plus there were all those reliability issues in addition to many cases where that SSD slowly degraded in performance over time. And then there's OCZ's relatively poor customer support.
Extremely overpriced. A good HD 6870 should not cost more than $200. Any higher and it's a ripoff.
That particular Antec is a semi-modular PSU. A lot of the cables are still attached. But it's a good quality PSU.
In regards to the Graphics Card, am I right by thinking a single Nvidia card cannot have 3 monitors connected to it?
After doing a little bit of research on modular PSU's, what fully modular power supply would people recommend?
Correct. If you need three monitors connection from a single GPU, see how much more the HD 6950 1GB or HD 6950 2GB costs.
$115 - SeaSonic M12II 620 Bronze 620W Modular PSU
$120 - Corsair 650HX 650W Modular PSU
$140 - NZXT HALE90-750-M 750W Modular PSU
$150 - Corsair 750HX 750W Modular PSU
$166 - Seasonic X750 Gold 750W Modular PSU
