Icestation
- Aug 6, 2008
I need some help,
Fist off I try not to be a AMD fanboy its just worked out that way my last few builds.
I do recommend Intel for a mojority of applications as the Core2's and i7 are crazy number crunching monsters. But for "my" needs AMD has fit the bill the last upgrade I did.
Now here is the problem. This 2 socket stuff from Intel, I have been reading most of the reviews on these i5's and while the numbers are impressive I still struggle with the socket! So what I would like help with is why did intel make it and what real benifit to me the consumer it has in the CPU/Motherboard arena.
So here are a list of my opinions please dont flame this I would like constructive critique to help me recommend this socket/platform right now.
1. why does it exist? from what I know it has most of the features from i7 minus a few (triple ddr, hyperthreading, vm support (not sure on this one). couldnt have intel made p55 for 1366 and just slapped on 4 dimms instead of 6 since i7 1366 does not have to have 3 dimms it will work with just 2?
2. what is with the model numbers the i7 870 is the same price as the i7 950 (actually 10 dollars more at newegg) for less CPU lower clock and missing some features.
3. If the anandtech pricing is correct for the p55 motherboards in this article http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=3624 hope its okay to link to an inferior website if not just delete the url please. there is no reason they could not slap the 1366 socket on a p55 motherboard and not pin out the 3rd channel of memory (i dont know if this is physically possible just a theory or reroute it just doesnt seem like this would be that hard to do considering AMD is putting ddr2 and ddr3 imcs in the same cpu cant intel figure out how to pin out a 1156 i7 870 or i5 750 to work in a 1366 socket? or make a i7 920/950 work on a p55 chipset without the gross overcharge for the x58 chipset?
So this is my big frustration I feel that the 1156 socket is a sham from intel like they are forcing us to pick a socket and then stick with it. or reinvest a bunch of money to jump to the next level and we all have seen sockets get retarded (AMD skt754,939,940 the early A64 days) I feel its intel being greedy and i have not forgot about the i3.
From a gaming standpoint I see i5 as killer cpu price/performance after the initial early adopter price drops. but from a heavy workstation view (cad/adobe) the i7 1366 is the first choice but if the budget is tight you have to pigeon hole yourself into a i7 1156 with a mysterious upgrade path, and from a budget build as of right now (i3 may change this but its 3-6months out) its hard not to go AMD am3 as its future looks a lot better then skt775.
and from a home user (web,ipod music and video ripper, and the family photo album) I see no reason in getting anything more then a PII 545 dual core for 89 bucks and a 70 dollar 785g thats loaded with options.
So any input would be great but as I see the 1156 its only purpose (other then specialized computing) I can put it in is the hard core gamer that cant scounge up another 200 bucks or so to make the full jump to i7 1366 with triple channel. even knowing the i7 1366 is overkill for gaming but when you spend 400+ on gpu's every year you are going to spend more then 150 bucks on a motherboard so you can get a couple of GPU cycles out of it.
If you read this thank you and please leave any opinions or comments to help me out or anyone else that might be wondering about this.
