1024x768 @ 75hz or 100?
mhenley
Monitor, Dell M991, 19" CRT.
Vid Card, Radeon 8500LE 64m
is there any danger in running continuously at 100hz? will it shorten the life of my monitor or card? will the card run hotter? will I see any performance decrease?
the higher the hz is, the better it is for your eyes (i think? someone verify this)
if both the video card and monitor can support it, then go for it, nothing to lose
Lower frequency will not hurt your eyes.
It's not likely that you'll notice any difference between 75Hz and 100Hz. Go easier on your monitor and use 75Hz, i'd say.
I can notice the refresh at 60hz. I will not play any game which forces the software to run in that mode, as it drives me nutty (hurts my eyes.) Its the same effect as you sometimes see on TV when they show a computer monitor. You see that line going down the screen really fast.
75hz and up doesn't give me that effect. I run in 85hz.
I don't think there is any difference running in a higher mode. Its kinda like a CPU, you can get 2.4 ghz on it, so why underclock it and run at 1.8? Sure it might be safer, but it was designed to run at 2.4... So its likely the component will fall apart due to other reasons (humidity and rust) before the stress you put on it.
totally depends on your eyes. i usually like to keep it above 85. if you can tell the difference or your eyes start getting tired i'd try it at 100. if the monitor is built for 100 it shouldn't be a problem
go for the highest Hz your monitor and card support at a given resolution
lower Hz DO cause headaches and is more strain on your eyes and brain, especially for prolonged periods of time
also in games having the highest refresh rate helps your maximum FPS if vsync is on
Difference between 75 Hz & 100 Hz I would think is apparent to anyone with decent vision & monitor.
wrong. 60 hz gives a lot of people headaches. I can defiantly tell 75 from 85.
running it at 100 hz will not hurt a thing
lower frequencies also tend to induce epileptic seizures (sp?). Remember the whole Nintendo fiasco years ago???? Yeah...caused by the refresh rates the game used on the tv.
I run my monitor at 1280x1024 @120Hz. I can go up to around 180 though. I usually run 3d resolutions at 120Hz also. The only reason I run it at 120 is because it is twice the frequency of 60hz, which also happens to be the frequency of AC power in the US. So if you have flourescent lighting and it causes interference with your monitor, changing it to 60Hz often solves it (did for mine, as well as the interference from a fan.) staying with a multiple of 60 seemed to work as well.
thats a badass monitor if it does 1280 at 120.
also flourescent lighting doesnt flicker like incadesent so that doenst make any difference at all. the only thing could be if its right by your monitor the inverter will generate a lot of EMI that could cause flicker.
What monitor is it? Brand & model?
Yes. . .please tell. I'm in the market for a new monitor and would definitely like one with that kind of refresh.
I'd like to see the make & model, I'd buy one.
Nokia 445Pro
21" (20 viewable), it's a couple years old though. surely they've improved on it since then :)
Nokia 445Pro
Thx for the reply.
Aperture grill I presume?
i cant stand anything below 100hz. so imagine if i have to work at 75hz.
most-note most- people do not see the flicker above 72hz. this is what they say-not me. i have noticed it to be somewhat true. most things are relative to the end user.
but it is very well known that the image not being constant will cause conscience/subconscienc drain as the eye will focus on each image drawn. the flicker that we tend to notice is a phosphorus decay. this is one reason why computers can be fatiguing.
when the refresh is set higher the image will be crisp. higher the refresh the better the image. after you see higher you will never want to go lower. this will also make redraws less fatiguing.
as one person said the higher the better (there are limits of the hardware as to how high you can go-read your manuals). this is in games and normal desktop interfacing. the monitor is the gateway to your computer. without a good monitor you are not truly enjoying your pc.
I run mine at 100 hZ all the time, it flickers and makes high-pitched squeels at anything lower than that... But, of course, that's my cheap, lame monitor, not most of them in general.
Thx for the reply.
yup. Flat screen, horizontal and vertical. .24 pitch also.
I've lost the manual, can't find it online, and the only page with specs I've found through google is here
and it's a press release...so not much good there. It only mentions a max res of 1600x1200 with a refresh of 115Hz. However, when I install the drivers for it, my max res is 2048x1536 and my max refresh rate is 180Hz (which I have tried at 1280x1024 and it worked...but I didn't leave it at that)
in case anyone else has one, it also has a nice service menu that you can adjust EVERYTHING about the monitor (color saturation, max/min settings, geometry, and a lot of other stuff I've never heard of). You can access it by holding the Menu button in for 4 seconds while turning the monitor on, then release it and press again. The password is 7711.
found the page for it...
viewsonic
max res is 1800x1440 from that page, and I just checked my display properties and tested 2048x1536 and it's a damned "virtual" resolution. but the refresh does go up to 180Hz.
wow, i didn't expect so many responses, i really appriciate it. 100hz, here we go.
