100MHz AGP X8
createcoms
Card= Albatron 5900EPV
Motherboard=Gigabyte GA-7N400 Pro2 Rev 2.0
AGP SBA Enabled Fastwrites Enabled
8x Mode (AGP 3.0)
AGP Frequency = 100MHz (highest gigabyte BIOS allow me to go)
Stability = 100%
:D :D :D :D :D :D
note to peeps who know agp overclock dont do much on 128MB cards: Hey its an overclock! ;)
no offense but I call bullshit, I dont think youre lying but I think the board or something else is lying...thats a little insane.
Overclocking the AGP frequency doesn't do much for you, since it only improves bandwidth that already is more than is necessary. Video cards can't even really use 8x yet, so giving the card even more won't be much of a performance factor. It also might not be good for your card but if you don't have any stability issues, it's probably not a big concern.
PCI-E cards with utilize the 16x PCI-E interface but also claim to be a bit faster. There are a few reasons for this, one being more efficient use of the bus for what does travel down there. Additionally DX10 will enable the use of virtual VRAM (most commonly seen in cards used for graphics rendering these days) which will make bus bandwidth more of a factor again.
How can I prove to you effectively my AGP bus is actually running at 100MHz? The nvidia system utility is showing 100 MHz, the BIOS is showing 100MHz. Let me know how I should prove it.
And yes Maxx I agree the performance increase has been minimal although I stress there was an increase (400 marks consistent in Aquakmark3).
But the point was purely to point out the overclock is possible. I searched the internet and found only articles where people had reached 70MHz and even then without total stability.
Uh, I fried a video card by increasing it from whatever was Default to whatever was one above default in the BIOS settings.
Originally posted by Yiffy
Thats an impressively tolerant videocard.
they don't build 'em like they used to. back in the BX chipset + coppermine days a card would have to go over 89MHz if you wanted to go past 133MHz fsb
Yep, My Diamond Viper 770 TNT2 had to put up with a 140Mhz FSB/94Mhz AGP speed.
Download Clockgen here...
http://www.cpuid.com/clockgen.php
take a screenshot and show us what it says for your AGP speed. i can set my agp/pci to 80/40 in my bios, but everything defaults back to 66/33 once i'm in windows.
if clockgen shows 100mhz, then i'll believe you :)
seconded
:p
Well, you get high AGP speeds if your motherboard doesn't have them locked. Although that's a K7 motherboard, it should have a lock.
Don't you know that KT400 lacks AGP lock? and obviously he doesn't have one..:rolleyes:
Well, i'm getting an a64 setup, and all motherboards lack the locks. It seems that i will have to ge a geforce, because the radeons would hold my overclock back (and geforce can tolerate higher agp frequencies??)
Ive been running 75Mhz on my 9700 and now 9800 for months.
I didnt realize til I tried clockgen that the PCI bus was locked..TO THE AGP BUS!!!!
So Ive been running 37.5Mhz PCI the whole time.
Testing at 80/40 now, will work up to 100/50 and see how the Siil3112 Raid0 likes the added PEP!
Yes but you can also set the AGP bus speed manually, essentially "locking" it to whatever speed you want. Or just think of it as keeping it independent of your FSB.
Why don't they just make our lives easier and put a divider on those things??? Then i wouldn't have to wait for a board that has a lock. Because so far, there are none for a64.
My Ti 4600 has been running on a 100 mhz AGP on my BX board for almost 2 years. I only backed it down when stability dropped through the floor when I put in a second 256 MB Dimm. BX boards don't like high FSBs with multiple dimms...had to back down from 150 FSB to 138 FSB.
Wait a few weeks or so for the nforce 3 250 boards to come out. They are supposed to have a fully functional agp/pci lock.
i believe that the nf3-150 motherboards now have a pci lock (at least the shuttle an50r does, a review i saw hit 300 or so fsb with it)
i wanna see a shot of this agp speed.
The shuttle board doesn't have a lock. Anandech was the one that started that rumor, and they also tested it later with an oscilloscope, to find that the frequency does change. It probably has a couple of dividers set up which will attempt to bring the frequency down to spec, however it's not a lock.
i think they tested the old revision. the new one (with a new bios) was overclocked to 300-some fsb, with no problems (after a vmod) i think that the nf3-150 had the pci lock all along, just not implemented or something like that. maybe it was a minor revision. anyway, i think the an50r NOW has a pci lock. when it first came out, i know it didn't. but i believe that they fixed that:D
i'll look around more tomorrow tho.
