$1000 Photoshop PC Build
Nurgle
Asked by a friend to help build a PC for photoshop. My knowledge on gaming PC's is good but I don't really know what goes into a beastly photoshop computer. Not sure if old PSU / GPU will be useful. Builds / general advice appreciated!
Photoshop & other Adobe suite software (Lightroom, Bridge, Illustrator, Flash). Some entry level video editing of short clips, but nothing too crazy. Working with large photo files so more RAM is a +
$1000 not including tax and shipping. Can overshoot this up to $300 if it means a big leap in performance.
3) Where do you live?
Colorado (close to Micro Center)
Motherboard, CPU, Ram, GPU*, SSD for OS & programs
Antec True Power Trio TP3-550 550W, LX-W Velocity Micro Case, EVGA Nvidia 8800GTS 320MB*, 2x 1TB hard drives, DVD Drive, Monitor, Mouse / Keyboard
6) Will you be overclocking?
Not immediately. Would rather overclock than buy factory overclocked hardware.
24" 1920x1200. May add 2nd monitor in the future.
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
USB 3.0, SATA 6Gb/s, RAID
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Yes - Windows 7 64bit
*Worth it to upgrade GPU? I'm still confused about the true performance boost from photoshop + cuda cards. Does it need a Quadro?
Edit: Budget is just for parts. Tax / shipping no longer a factor.
How close the MC are you? What's the sales tax (if any) for your state/county?
Anyway, you should be ok with the current GPU. The PSU on the other hand I'd replace just to cut off any potential issues.
Alright, shipping and tax are no longer a factor for the budget. $1000 is the target, but not a definitive cut off. It won't matter if shipping and tax set things a bit over.
Thanks for the advice Danny_Bui. I was debating if the PSU needed to be upgraded or not. My friend said the budget can be raised to accommodate a new power supply if needed. Micro Center is a 20 minute drive, so any CPU / Mobo combo deals would be easy to pick up.
All right go for the 2500K from Microcenter as well as any of these mobos:
$130 - MSI P67A-G43 Intel P67 ATX Motherboard
$133 - MSI P67A-G45 Intel P67 ATX Motherboard
$160 - MSI P67A-GD55 Intel P67 ATX Motherboard
$180 - MSI P67A-GD65 Intel P67 ATX Motherboard
SSD wise, go with Crucial M4 series SSDs or Intel's 510 series SSDs. 64GB should be enough for the OS and programs.
RAM wise, go with two sets of this RAM:
$50 - G.Skill Ripjaws F3-10666CL9D-8GBRL 2 x 4GB DDR3 1333 RAM
PSU wise, I recommend this:
$70 - Antec NEO ECO 620C 620W PSU
$70 - Antec High Current Gamer Series HCG-620 620W PSU
