Gaming (Primarily Bad Company 2, and eventually Starcraft 2, Diablo 3, etc)
Autocad
Solidworks
Matlab
Web Browsing
1080p movies (don't need blu-ray, have a ps3)
$1000 including tax, shipping, and after rebate prices. I have already spent $283.90 on a CPU and case. So ~$716 for everything minus cpu and case. Preferably priced out on tigerdirect so I can make use of no tax and 15% bing cashback.
3) Where do you live?
Central Coast California
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Case
Power Supply
CPU
Motherboard
Video Card
Ram
Hard drive
DVDRW
None
6) Will you be overclocking?
Maybe a little bit on stock cooling?
Acer 22" 1680x1050, and occasionally Sharp 46" 1080p 120hz
Before Bad Company 2 comes out (March 2nd)
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Optical audio, or coaxial (digital audio for my receiver, which does not have hdmi)
Don't need crossfire support (from what I have read, single high power card is better for the 860 and the lack of 2 16x pci-e capability will hinder performance if I decided to get another 5850 in the future)
Possibly RAID in the future, though not that big of a deal
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Windows 7 Professional 64 bit
Right now I have (already bought):
i7 860 (got it for $199 + tax = $218.49 from microcenter)
Antec 300 Illusion ($61.99 + tax + $9.99 shipping - $12 rebate)
In my tigerdirect shopping cart:
$299.99 Sapphire HD 5850 http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5260768&sku=A271-5850
$124.99 EVGA P55 LE http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5083732&CatId=4720
$134.99 Corsair XMS3 DDR3 1600mhz http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5082126&sku=C13-8248
$94.99 WD Black 1TB http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4034139&sku=TSD-1000WD
$109.99 Corsair TX750W http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3438609&sku=C13-2503
$25.00 Samsung DVDRW
Total: $789.95 - 15% cashback = $671.46
Background information: Last time I built a desktop was ~5 years ago, with an Athlon64 and Ati 9800pro. I did overclock it (had a Zalman hsf on it) along with the video card so I am not a total novice at overclocking. Should I consider overclocking? I have no clue on how these new HSFs are with heatpipes and what not, and if they're worth the extra $40 or whatever for the extra overclock gain + the cost of artic silver 5 or whatever you guys use these days. I don't plan on upgrading in the next few years.
Other concerns: Should I save some money and go with 1333mhz ram and a lower-end motherboard ($90+$80 vs $125 + $135 Such as this http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5608207&csid=ITD&body=MAIN#detailspecs and http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5210464&CatId=3361)? The difference is $90 but that OCZ ram seems sketchy, with so many reports of DOA. I imagine that motherboard doesn't have much in terms of overclocking ability as well.
Is there any significant difference between H55 and P55 other than the on-board video capabilities of the H55?
Should I get the 5850 or pay a little more and crossfire 5770s? Will the 5770s be noticeably hindered due to the 2 8x instead of 2 16x pci-e support?
Should I buy it now while tigerdirect cashback is at 15% (it has usually been 8-12.8% in the past) or wait another 2 weeks in hopes of price drops?
Non-related, future considerations: I have a pair of Grado SR125s, Logitech z-560s (400w 4.1 system, pretty old), will occasionally use the 5.1 system in the living room, and dabble in guitar and keyboard (I suck). Any point in getting a dedicated sound card or is there not that significant of a difference in audio quality?
Autocad
Solidworks
Matlab
Web Browsing
Case
Power Supply
CPU
Motherboard
Video Card
Ram
Hard drive
DVDRW
None
