As a preface, what I'm going for is a gaming machine that will play the games listed below at acceptable frame rates (for FPS preferably 60 fps) and moderate to high graphical quality, preferably at my display's native resolution. If my budget is insufficient to meet those goals please let me know what is realistic -- my hardware knowledge is rusty.
Gaming and rarely transcoding video. Games I currently play are Eve Online, TF2, BF:BC2, Starcraft 2. Games I am looking forward to are Portal 2, Diablo 3, and Battlefield 3. Infrequently I use Handbrake to transcode video. I will do the bulk of my web browsing on my Macbook.
Approx $725, tax and shipping included, but I do have Amazon Prime which saves me from both. Newegg also doesn't charge taxes.
3) Where do you live?
Omaha, NE (68154) No Microcenters or Fry's nearby.
CPU, GPU, HDD, motherboard, power supply, CPU cooler (not opposed to stock), DVD or BD-ROM.
Antec 300 (got it for $20 with combo codes after MIR, I couldn't believe it), GSkill Value Series 2x4GB 1333 DDR3, Logitech G500, old Logitech wireless keyboard
6) Will you be overclocking?
I have not overclocked systems in the past, but I'm not opposed to doing moderate air cooled overclocks.
NEC 23" IPS EA231WMi 1920x1080
Between now and the middle of April.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? etc.
Firewire 400 might be helpful for a few legacy items, but isn't required. 6 Gb/s SATA and USB 3.0 would be nice, but not necessary.
I do not have a reusable license. Please include any license costs in the budget.
I'd like this computer to be unobtrusive since it will likely be put under or beside a desk in my den. While silence isn't required, I also don't want to be sitting next to a leaf blower that illuminates the entire room.
I don't have any allegiance to Intel, AMD, or nVidia. I'll try Crossfire/SLI, but I would prefer to get a GPU that is good enough now and then upgrade with a new single card solution when required.
Items I have yet to buy are:
CPU: Intel i2500k $220 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Motherboard: ????
GPU: XFX HD-687A-ZNFC Radeon HD 6870 1GB $180 after MIR http://www.newegg.com/Product/Product.aspx?Item=N82E16814150506
HDD: ???? 1 TB
PSU: XFX P1-650X-CAG9 650W $50 after MIR and coupon http://www.newegg.com/Product/Product.aspx?Item=N82E16817207002
DVD: ???
OS: Windows 7 Home Premium 64-bit OEM $90 after coupon http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
Total: $540 before undecided items. Also, I need to jump on the PSU very, very soon and I'm ordering the OS tonight since I'm fairly certain it won't go lower than $90 outside of a combo deal. I'd like to get the CPU soon because of the Shogun 2 combo (effectively saves me $40 versus buying it seperately.)
Motherboard: ????
HDD: ???? 1 TB
DVD: ???
