$1000 Gaming PC
Superfly3176
Building a PC for my cousin, he finally came into the cash he was due so he wants to build within a few weeks. I asked about this earlier when he mentioned it, but he just wasn't ready to build anything then. Thanks for the help :D
Gaming
$1000 with tax and shipping
United States 17801
CPU, Ram, HDD, Video card(s), motherboard, Blu Ray or DVD drive. Unsure of Power supply yet. Most likely won't need a monitor, and won't need keyboard + mouse
This is the power supply he has.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817121025
6) Will you be overclocking?
No
21" 1680x1050
Within a week or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
SLI - He wants to go with nvidia cards
No, need a 64-bit OS.
SLI is complete over kill for any single monitor setup, much less a monitor with only 1680x1050 resolution. I don't think he will even notice a difference in SLI with that low of a resolution to be honest.
If you aren't overclocking, then the i5-2400 is probably a good choice. Pick an MSI P67 motherboard and 8GB of RAM to go with it, and then either a GTX 560 Ti or a GTX 570 for video and you'll have a good core setup. How big a hard drive are you looking for?
$189.99 Intel Core i5-2400
$114.99 MSI P67A-C43 (B3) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
$46.99 G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
$329.99 EVGA 012-P3-1571-AR GeForce GTX 570
$59.99 SAMSUNG Spinpoint F3 HD103SJ 1TB
$99.99 Microsoft Windows 7 Home Premium SP1 64-bit - OEM
So that's $841.94 without mail in rebates.
There is a combo on the i5-2400 and a Corsair 650TX V2 if you need a new PSU:
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.744471
Do you guys think 16gb of ram is overkill? or future proof?
Overkill, but it depends what you are using the computer for. However, given the low, low price of RAM nowadays, it isn't a terrible value for the money. But it is doubtful that mainstream uses will require that much RAM in the near (2 - 3 year) term.
16GB of RAM is definitely overkill. But considering that DDR3 RAM prices are soo low, I say get it if you have cash to burn.
Ended up getting it for him. At only like 45 bucks more then 8g was hard to go wrong...
Plus his last PC he kept for 6 or 7 years and just did upgrades to it so at least ram wise it'll be future proofed.
