$1000 Gaming Build
OC32
Gaming - GW2,D3
$1000 Shipping Tax included
US, Orange County CA, I live close to a Microcenter
Case, memory, CPU, MB, SSD, GPU, storage drive, Power Supply, DVD
None
6) Will you be overclocking?
No
24" 1920x1080
Could order parts any day
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB3
I have a 64 bit win 7 license
Prelim build:
$285 - Intel Core i5 3570K + Asus P8Z77-V LK Intel Z77 ATX Motherboard Microcenter Combo
$66 - G.Skill Value Series F3-10600CL9D-16GBNT 2 x 8GB DDR3 1333 RAM
$289 - eVGA 02G-P4-3660-KR GeForce GTX 660 Ti 2GB PCI-E Video Card
$105 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$89 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$18 - Samsung SH-222BB/BEBE SATA DVD Burner
$57 - Antec NEO ECO 520C 520W PSU
$50 - NZXT Source 210 Elite White with Black Front Trim ATX Case
Total: $954 plus tax and shipping
Thanks Danny, getting ready to order. Is this GPU a better choice for the same price?
Sapphire hd 7950
Also, is it worth the extra 100 to bump up to a Corsair HX650 PSU and 300R Case?
Yes and no: The HD 7950 3GB will be faster but Sapphire isn't as good of a company as eVGA when it comes to customer support and warranty. Not to mention that Nvidia's drivers are slightly better than AMD at times.
Sapphire hd 7950
Yes if you can afford it.
I ended up going with the Corsair 300r Case and HX650 PSU. Ended up getting a Gigabyte 7870 GPU as well. I have everything built and running but when i fire up a game i keep hearing a fluddering beeping sound from what sounds like the PSU. Is this common? Did I get a bad one? It only happens when under load.
Yeah good choice, Only thing i would change is the ram could have saved $30 and bout 2x4gb ddr3 1600.
