$1000 gaming build
Gaming: Diablo 3, League of Legends, Tribes Ascend, maybe something like Borderlands 2 down the line.
$1000 roughly, no sales tax here (OR)
OR - Corvallis, nothing nearby
CPU, RAM, Mobo, Case, GPU, PSU, DVD, SSD if possible
750GB WD Caviar Black
6) Will you be overclocking?
I never have, but am open to the idea.
7) 7) What is the max resolution of your monitor? What size is it?
1920 x 1080 - 23"
ASAP
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
No, I will need a copy of Win7
Is that copy of Win7 part of that $1000 budget?
I would say so, but I'm fairly flexible so if there's a sort of breakpoint that requires going over by the cost of win7 I could be ok with that.
Here's a prelim setup:
$230 - Intel Core i5-3570K CPU
$135 - MSI Z77A-G45 Intel Z77 ATX Motherboard
$38 - G.Skill Value Series F3-10600CL9D-8GBNT 2 x 4GB DDR3 1333 RAM
$358 - Asus HD7870-DC2-2GD5 Radeon HD 7870 2GB PCI-E Video Card
$22 - Lite-On iHAS424-98 DVD Burner
$65 - Antec Earthwatts EA650 Green 650W PSU
$55 - NZXT Tempest 210 ATX Case
$100 - Windows 7 Home Premium SP1 64bit OEM
Total: $1003 shipped
I think there is better GPU value by picking a 7850 for much less or a 7950 for slightly more. 7870s especially the premium versions are very poorly priced. You could buy a SSD with the savings from dropping down to 7850 and you will still be able to OC to nearly the same performance as the 7870OC. Similarly adding $40 to get to a 7950 opens up a card with tons or headroom.
Personal preference but if I am spending 1k+ on a rig I am chosing a case I wont hate looking at for the next couple years so maybe budget more for that item.
The reason why I didn't go with that route was because there wasn't enough room in the budget for a HD 7850 from a reputable manufacturer or a well priced SSD. It was totally possible to grab a SSD and HD 7850 for that same amount of cash but it would either require you to grab a HD 7850 card from a not-so reputable manfuacturer (This HIS 7850) or a poorly priced SSD (the Crucial m4 64GB)
But if the OP is willing to go over budget by another $34, then I definitely recommend the route you suggested:
$125 - Crucial M4 CT128M4SSD2 2.5" 128GB SSD
$267 - Gigabyte GV-R785OC-2GD Radeon HD 7850 2GB PCI-E Video Card
Total: $392 shipped
Correct. There wasn't enough room for a better case. At least, not if he wanted the ability to OC.
As usual you were right. The $250 7850 I had in mind are out of stock on Amazon. I probably would still opt for the Gigabyte785OC you selected before I bought the 7870 from earlier. OP has some decisions to make at least. There is also that 6950 deal for a few more hours if he wants to cut the GPU down further for SSD or case options.
There's a Fry's electronics in Wilsonville, which is about 70 minutes northeast of you.
Total: $392 shipped
I like this option.
As far as the case goes, I'm not too concerned with aesthetics.
I saw this and was interested in it, but I really don't know enough about current hardware to know if that would be a better option.
SSD and Case aside, do you think it's worth the $60 to go with the 7850?
I would buy the 7850. Even though the difference at stock speeds may not be worth $60. The OC ability of the 7850 makes it a far superior card on performance and overclocking these days is ridiculously easy thanks to software. 7850 also runs cooler and uses much less power. It is a tough call based on pure budget but only because that 6950 sale.
