Gaming(BF2, Crysis, SC2, Diablo 3, newer DX 11 titles), web browsing, movies, music, ms office, general use
$1000 before tax and shipping
3) Where do you live?
Michigan
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
I have the case, i need everything that goes inside of it
keyboard, mouse, speakers, monitor, case
6) Will you be overclocking?
Yes, but not right away
24" 1080p
Ordering parts in 2 weeks
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
Crossfire and RAID
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
EDIT: Yes, win 7 pro 64bit.
For the case i recently purchased a LIAN LI Lancool PC-K62
UPDATED
Final build order placed:
$130- (Bought unopened off a friend) MSI 890FXA-GD70 Motherboard - AMD 890FX, Socket AM3, ATX, DDR3, RAID, SATA 6.0GB/s, USB 3.0
$159- AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
$409- XFX HD587AZNF9 Radeon HD 5870 Video Card - 1GB GDDR5, PCI-Express 2.0, CrossFireX Ready, Dual DVI, Display Port, HDMI
$119- Antec TruePower New TP-750 Blue 750W Continuous Power ATX12V V2.3 / EPS12V V2.91 SLI Certified CrossFire Ready 80 PLUS BRONZE
$110- G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-4GBRL
$55- SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
$25- ASUS Black 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 12X DVD-RAM 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA 24X DVD Burner - Bulk - OEM
Some of these were ordered off Tiger Direct for 12% Bing cashback
This is going to be my first build, thanks in advance for your help!
Michigan
24" 1080p
Crossfire and RAID
UPDATED
