Regular browsing, music encoding, DVD encoding and gaming.
My budget is somewhat flexible, obviously the cheaper the better but I'm looking to spend less than $1300 all together.
3) Where do you live?
NJ
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
Everything minus a DVD burner.
Samsung DVD+-RW
6) Will you be overclocking?
Yes, I plan to.
Dell 2407.
This month.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
I don't plan on ever using crossfire or SLI because I want this machine to be as energy efficient as possible and usually when I upgrade cards, I buy a new one not add another one.
10) Do you already have a legit and reusable/transferable OS key/license?
Yes.
I'm confused whether to go with dual channel RAM or triple channel, is there a real performance difference between the two? Because of this confusion I don't know what kind of motherboard to get or which socket 1156 or 1366. The thing I know that I want are the following.
Antec P183: http://www.newegg.com/Product/Product.aspx?Item=N82E16811129061
Seasonic X650: http://www.newegg.com/Product/Product.aspx?Item=N82E16817151088
I want to make very clear that this machine needs to be efficient with power that is why I am going for the 80Plus Gold PSU. If you can convince me that a lower standard 80Plus PSU can do then I will do it but from what I've read, this is the best. So I need high efficiency and low heat + noise. This seems to be the perfect PSU even though it is pricey.
The case is also good with cooling and is low noise which is why I picked it.
The rest of the parts are up to you, I would post my build but I feel embarrassed by the lack of knowledge with current computing so I'll leave it out. Thank you.
NJ
Samsung DVD+-RW
Yes, I plan to.
Dell 2407.
This month.
Yes.
