AliceCooper
- Mar 25, 2007
How well do you think an 8600GTS 256MB will do as a physx card? I have a buddy who wants to use it as a physx but they only have 32 shaders. This is paired with a GTX570 SSC.
for sub $100, nothing.
Maybe if your talking about a single card that can handle graphics and PhysX, but for a separate dedicated PhysX card I think there are lots of choices under $100
$291.99![]()
I have the same card....they are worth about $40 now (if you are lucky). Sorry to be the bearer of bad news.....a 9800 GT will blow it out of the water. At least I got my Ageia card for only $160lol
The card is worth what someone is willing to pay for it.![]()
If you have a spare 8600gt laying around sure, it does decently. My 9500gt (roughly the same thing) handles physX fairly well. High apex is playable in mafia 2 except in HEAVY HEAVY scenarios, then medium works well. But my 460 handles it better by itself, I wouldn't buy anything less then a 9800gt for it...
While taking the main load off the main card, if it is too slow at performing the PhysX operations it can hold up the graphics card while it waits for the PhysX result
Just having a dedicated PhysX card is not always beneficial for this reason. You need a card that performs above a certain threshold or it can still hurt your performance
Because a GeForce GTX260 pulls 25w idle / 182w load, where as the similarly performing GeForce GTS450 only pulls 18w idle / 106w load.Why don't you get a USED GTX 260/216 cores? They go under 100 now.
