I looked into hard drives for my 360. didn't want to shell out 130 for a MS one or anywhere upto 100 for a chinese one.
came across some interesting threads where people were flashing Some WD Scorpio Blue/Black drives for use in 360's (both regular & slim)
Well if the factory is using 5400rpm-ish drives and a 7200rpm drive is snappy...10k would be amazing. what would it take to shove a Velociraptor into one?
The answer is: a 12v feed, a fan, a razor, a bit of solder, and a little firmware trickery (the same software you use to flash the scorpios works on velociraptors too!)
The results: shaving an additional 5 or more seconds off my average load times compared to my old 20gb drive i had installed in my slim.
Since it is thicker you can't use the drive cage/case and it fits perfectly in the bay without it. You wouldn't want it in any sort of case anyway due to heat. the fan blows directly over the bare drive.
Give it a day and i'll have a somewhat decent writeup done. I only have a couple pics because most of it is already covered in the teardown and reassembly tutorials already widely available online.
