1 Million point challenge
  • Thread starter Deleted member 88227
  • Start date
SPT is 28
ODLK2025 got me to 57 total 1M projects. Currently this project is down. I may run it to 10M when the project is up and running again.
Thinking about running docker for the BOINC Central but need to setup new ubuntu install with ver 24.
I've got one host running WSL
#58 for BOINC Central after setting up one SSD/PC with Ubuntu 24.0. Didn't get any success with Windows 11 as all my BOINC SSDs are still on Windows 10. Actually I don't mind running linux OS.
I have had a hard time getting BOINC Central set up on the linux systems. Seems I can't get docker sorted for this one. Any guides you recommend?
I followed this guide here: https://boinc.berkeley.edu/central/forum_thread.php?id=28 for linux
Are you having issue with launching the boinc manager or the project (boinc central) itself? Initially I had issue with the boinc manager (8.2.5) but using this command solves the issue on launching boinc manager.
Code:
sudo usermod -aG boinc your_username_here
I did a fresh install for ubuntu 24.04.3 as I don't want to mess up with my older ubuntu version. Make sure you have podman installed on your PC by clicking on "Details" in your boinc central account. I think anything higher than Podman version 4.9.3 will work. Just my guess as I notice that there are newer Podman versions available.
Code:
CPU type    AuthenticAMD
AMD Ryzen 9 3950X 16-Core Processor [Family 23 Model 113 Stepping 0]
Number of cores    32
Coprocessors    NVIDIA NVIDIA GeForce GT 1030 (1985MB) driver: 550.99
Virtualization    ---
Docker    Podman version 4.9.3
Operating System    Linux Ubuntu
Ubuntu 24.04.3 LTS [6.14.0-33-generic|libc 2.39]
BOINC version    8.2.5
Isn't BOINC Central just another version of Science United and both by David Anderson? Haven't dug far enough into it to care after seeing his name on it.
Project.
Manager is fine and other projects running. BC kept giving me docker error message, even after following the instructions on the BOINC site to install podman and verify it was installed.
Something wrong with my systems when using these instructions:
Install Podman
Some BOINC projects use Docker to package their applications. We recommend that you install Podman, an open-source version of Docker. To do so:
sudo apt install podman
sudo usermod --add-subuids 100000-165535 --add-subgids 100000-165535 boinc
Project.
Looking at one of your hosts: https://boinc.berkeley.edu/central/show_host_detail.php?hostid=42251, no Podman was installed. See "Docker ---" at least according to BM.
Here is mine. I think Ubuntu 24.04.3 may come with pre-installed Podman and I think the linux gnome has minimal packages that goes along with it. BM 8.2.4 should work too at least from what I read but if it doesn't work, try 8.2.5 (alpha version). Anyway, I've this on a separate SSD, so easy to do a clean install.
Yeah...I think basically it is. Science United is more for those looking for an extremely dumbed down way to support science. BOINC Central is being set up using the latest and greatest which typically requires more technical setups. IE: setting up WSL/podman vs just logging into an account.
So, axiom wasn't listed in Free-DC and the project was dead after it ran briefly, iirc less than 2 months or so.
Anyway, Eternity II gets me to #60 1M project.
Bitboinc is being boycotted by the stats sites for various drama related reasons. Therefore it as well is not included on free-dc to count the tally. This would give me 76 BOINC projects.
For the same reason on Axiom, that would make 77 BOINC projects
Bitboinc launched its first sub-project on finding lost bitcoin. Initially there were some criticisms/uspicions/FUDs about how the money will be distributed IF and when the puzzle is solved. After the drama, the admin clarifies it a few days later in this post. Probably not the best way to start up a new project but subsequent sub-projects are not related to bitcoin which is great. When money is involved, trust, honesty and transparency are very important. Anyway, I'm hoping that the stat sites will reconsider adding Bitboinc project in the future.
Beacon@Home and Kessler@Home push me to a total of 62 1M projects.
Two more projects needed to be on par with RFGuy_KCCO. May do thepuzzle.cloud and bitboinc as the latter is not added to the freedc and boincstats website.
