HeavensCloud
Oswego, not shitty as Buffalo
- Feb 7, 2008
Since this system is custom water cooled I have to drain the loop, remove the GPU, air cool the cpu, pull my sons 6700xt gpu, plop it in and make sure my brand new motherboards PCIe slot isnt the culprit.
I would check the 6900 in his machine too. I had a 980ti that did the same thing but worked fine on another system. Long shot, but worth it.
