thewhiteguy said:Get the 1/2" to 3/8" adapter kit for the pump, you'll want that.
The barbed part on the pump is more like 5/8" or more, and it's hard to do. With the soft tubing it's even harder because you can't really press it on there hard since it just collapses.rtierney said:i won't be able to squeeze the clearflex 3/8" tubing over the 1/2" inlet/outlet?
given a difference of only 1/4" I thought i'd be able to strech it over and have a tight seal.
if i can't, i'll just run down to the hardware shop and buy a 1/2" to 3/8" adapter.
Swiftnet sells MCP600-RK, the adapter kit, for $2.21. I don't know who else sells that or for how much, but I'd say it's worth it to avoid the trouble.rtierney said:In that case, will I need to pick up a 1/2 to 3/8 adapter?
NightStalker said:sounds like a nice system.....
where you brought it from and how much did it cost?
rtierney said:Mostly from sidewindercomputers.com, but I bought 4 things from dangerden.com, such as the heater core, tubing, clamps, and poly res.
The total including shipping from both places was about $340.
A bit high, but I figure the parts will all stick with me for the next few systems I go through.![]()
++thelostrican said:gary from sidewinderscoputers is the bomb, he ships out stuff super fast and is always there to awnser the emails.
