you actually got the software to install?! that's an achievement in itself. I was asked by a coworker to set his up and couldn't get any version of the software to install on 2 different pc's. He ended up taking it back.
Then you have no freaking idea what you were doing. I've installed it 4 times on 3 different computers (had to reformat one due to a completely unrelated problem. ) and EVERY SINGLE TIME it went without incident or error.
If you use this ( http://www.sofotex.com/Zune-Explorer-Enabler-download_L56162.html ) It might work, but I don't know if the library list will automatically update. You may need to reboot it after adding songs (Back + Up on DPad for 5 seconds )
Were you trying to install it on Server 2003 perhaps? Won't work. I know this from experience. Microsoft, in it's infinite wisdom has decided to not allow the zune software on any of the server OS's - or Windows 2k (not certain about that though)
Works fine on Vista and XP though - and the latest update really isn't that bad.
Got an 8 gig flash Zune myself (so I can play it in my boat - rough water, high speed and HDD's don't mix) - plan to get an 80 gig for the car totally happy with my Zune.
