- Feb 24, 2005
In regarads to getting power to the Zune, I know that according to the manuel it states that you would just power it through the USB cable provided.
I know that you can buy a power "bug" for it and power it through the wall but I would like to know if that power "bug" is similart to how the iPod power plug adaptor works by using the USB cable.
If it does, then I can use the power adaptor I have for my dead iPod instead of spending $40 to get a new one for the Zune
