zpool export import alternate cachefile
RandyV
Hi all,
Using openindiana latest build (a6)
I'm experimenting with creating zpools with an alternate location for the cachefile. Reason: I don't want certain pools to mount at boottime. I know that you have to create a copy of the cachefile so that it won't be removed when you export it. I followed the following procedure (done in a vm and on real hardware)
1: Create e.g. a very simple pool with the command:
zpool create -o cachefile=/etc/cache/testpool.cache -f testpool c2t1d0
2: copy /etc/cache/testpool.cache to /tmp/
3: export testpool :zpool export testpool (original cachefile gets deleted automatically)
4: copy the cachefile back to original location: cp /tmp/testpool.cache /etc/cache/
5: import the testpool back: zpool import -c /etc/cache/testpool.cache -a
Step 5 is where it goes wrong. I allways get the message: "cannot import 'testpool': one or more devices is currently unavailable.
If I do an import -f testpool, there's no problem. I find this bevaviour a little strange. Probably I'm missing something.
Maybe somebody can shed some light on this?
Rgds,
Randy
The above mentioned steps do work ik oi version a5.
So probably a bug in version a6
Rgds
