I am currently rebuilding my HTPC and I thought I would share some experiences.
My primary goals in rebuilding my htpc are add more storage to my existing htpc while adding efi bios support for <3tb hdd support, including having usb 3.0 and esata. While simultaneously adding a little cpu horsepower. I also wish for over clocking support. The board that seems to fit the bill is the Zotac Z68 A-E.
After all the horror stories of bad zotac z68 boards I stumbled on a solution. Ewiiz currently is currently offering a code for free assembly and testing of systems. My plan is to have them weed out doa boards and boards with bad ram slots.
Now at this point you may be asking why should I care just another build right? Well the things that will most likely interest you are a. I will not be using the wireless card in the Mpci-e slot but this instead Mini PCIe Sata. and b. Using the onboard usb 3.0 front panel connector with this USB 3.0 converter with this USB 3.0 Internal sata adapter.
The reason why you ask? I need more that 4 sata ports. I wanted to find a Z68 board that allowed overclocking (Subject to bios limitations). Had a msata / mini pcie slot that could actually be used for non wireless cards.
The system will have eventually have 6 hdds and one optical drive. I can do this without the bottom hdd cage because of the slim optical/3.5 hdd adaptor I am using in the main 5.25 bay. It currently houses the slim optical and a 2.5 inch drive but the laptop drive can be moved to the often overlooked 2.5 inch mount in the q08 underneath the 5.25 bay. So for those keeping count 4x hdds in the main cage 1x 3.5 hdd in the 5.25 with a slim optical drive and 1x 2.5 in the 2.5 hdd mount.
The sata card has 2 ports. Unfortunately due vertical nature of the slot and the position close to dimm slot #1 the first port may not be usable. I will see if maybe a right angle cable will fix this. I should have enough sata ports but in case I can’t use them all due to compatibility or port placement I have a backup plan. The usb 3.0 front panel header will allow me after adaptation to use up to two internal usb 3.0 sata adapters in case I am lacking the necessary sata ports to add all these drives. I don’t think the main cage will allow me to use the usb 3.0 sata adaptors because of the fact that the usb cable when plugged in to the adaptor will not allow the side panel to close. I will see if this is the case.
The internal usb 3.0 option is more of a backup plan in case the board hates the sata controller or more likely that one of the sata ports gets blocked by the 1st dimm slot. The board lacks esata as well.
The Lian li Q08 (at least the version I have has the classic usb 3.0 front ports that require routing to the back of the case. The always seemed like a hack job to me but in this case it wouldn’t work either if I need the spare pci slot bracket cover to add a esata port. Now I know I can get an usb 3.0 to esata dongle but I always prefer native esata over usb 3.0 any day of the week. The usb 3.0 front panel header adaptor lets me add devices internally usb 3.0 or have the front panel ports on the q08 be usb 3.0.
Old HTPC
Cooler: Coolermaster Gemenii
Cpu: Phenom II 905e
Motherboard: J&W Minix 780g
Ram: 2x2gb ddr2 800 Gskill
Video: Diamond 4770
Hdd 1: 2tb 7200 rpm Hitachi
Hdd 2: 1tb 5400 rpm Samsung 2.5
Optical: Sony bluray combo slim optical w/sata adaptor
Case: Lian Li Q08
Power Supply: Antec Neo 550
New: (intially)
Cooler: H50
Cpu: I5 2500k
Motherboard: Zotac Z68 ITX A-E
Ram: 1x4gb ddr3 1333 Supertalent
Video: Diamond 4770
Hdd 1: 2tb 7200 rpm hitachi
Hdd 2: 1tb 5400 rpm Samsung 2.5”
Hdd 3: 2tb 5400 rpm Samsung
Hdd 4: 2tb 5400 rpm Samsung
Optical: sony bluray combo slim optical w/sata adaptor
Case: Lian Li Q08
Most people are focusing solely on the overclocking experience and the bios glitches I hope to focus more on the whole package. I do intend to overclock but my main concerns are how to add addition storage both now and future give board/case/ lack of sata port limitations.
Old HTPC
Cpu: Phenom II 905e
Video: Diamond 4770
Case: Lian Li Q08
New: (intially)
Cooler: H50
Cpu: I5 2500k
Video: Diamond 4770
Case: Lian Li Q08
