Zotac 3060ti Loaded CPU with Furmark, HWiNFO64 reports low 70s Temp but 82 Hot Spot
DWD1961
As the title states, with the CPU running at A MAX OF 82C (78C avg) nd Furmark running full blast, HWiNFO64 reports 73 MAX GPU but 82 Hot Spot (max). This is on a non OC card running the factory fan profile. I noticed on another site that the #1 fan on this Zotac card will spin to 5000 RPM! The highest it spun with the factory fan profile was 2000 RPM. I'm just wondering if those temps are too hot. If so, I'll load Zotac's Firestorm up and adjust the fan profile.
