Zombie-Strike ....how do you remove it?
Force Flow
I installed the zombie-strike cfg scripts (but not not the models), it runs when I create my own server, but not well. Other players have a really hard time connecting to my server (ie, lag). Also, I can't connect to servers anymore. It takes a half hour to connect, and when it does, it's extremely laggy (as in a 10 sec delay)
the console command to run it was "exec zombieCT"
I deleted the cfg files, but when I try to create my own server, it still seems to be running. How do I get rid of it? Is there an unload command?
Here's where I downloaded it from: http://ferus.shackspace.com/zombie_strike.html
[edit]: If I wasn't clear earlier, this is for CS:Source.
I've been scouring the net all day trying to find instructions on how to get rid of it, but all I can find are instructions on how to install it. Does anyone know how to get rid of it? I'd really appreciate it, thanks :)
