zipzoomfly?....
spotdog14
Ok, so most of you guys here like zipzoomfly better than the egg (i have been using hte egg since it was founded). But the main problem i have with zzfly is that nothing is ever in stock! I have been waiting for one of two tv tuner cards to come in stock for literally 4 months now...WTF?
Has anyone else noticed this?
They're probably just waiting for someone to place an order before they restock. Would you buy 10 7800GTXs if no one would buy them from you?
That's my guess, anyway.
the one item you want is not in stock so now everything at ZZF is not in stock? I don't know - I usually pick out what I want, then look at newegg, mwave, and ZZF and see who's got the better deal after shipping. If your item hasn't been in stock for four months, geez find some place else to buy it from!
I've noticed this as well, although it's usually the more obscure items.
On a good note I noticed they recently started selling OCZ RAM and Seasonic PSUs.
Their product list just isn't very well controlled. I don't think they update it as often as they should. Anyways, if they don't have what you want... go somewhere else.
no its not everything is out of stock, its just take for instance the tv tuner section, there are only like 10 in stock and a page and a half that are out of stock.
And yes hte ones that i want are abscure, that is why i went to zipzoomfly in the first place because they carried them!
I ordered about $700 worth of stuff from them on FRIDAY morning. I ended up finding a better deal at newegg so I went back to cancel on SUNDAY. Only then did I see something just updated to "on back order". I was never even emailed to tell me this? That and the fact they dont have an 800# or answer the phone after 5:00 PST makes me think I should stick with egg.
