Zip Tie Anchors Where ?
Darkatom
Anyone know where I can pick up a bunch of Zip Tie Anchors for some cable management ?
Have you tried xoxide.com, crazypc.com, or .performance-pcs.com? Even newegg might have somthing like that. Local electronic stores would also be a good place to check out.
Radioshack has a good amount of cable management stuff as well....Home Depot works just fine too.
I'm 90% sure petras has them. I remember ordering a bunch from a site, pretty sure it was petras. They are small however.
If you want big ones, I'd go to Lowe's or Home Depot.
I'll go ahead and go down to home depot later today. I really didnt want to order any online as the shipping cost would probably be more than the actual anchors.
