agreed, it's cheaper. i'd personally go with the flash because i'm in a different situation, i was just recommending something for him. however, as to the long long life of flash devices, i'm gonna have to disagree. certain bits are written more often than others (mft/fats) and so those die earlier. i believe windows even writes certain bits on mount of a new disk, so every time you plug it in it it loses reliability. and while manufacturers may quote 1e5 or 1e6 write cycles, they also quote 150+ years mean time between failure. i don't know about you, but I haven't had a disk last even 10 years.stevewm said:With flash memory each bit can only be erased and re-written so many times. Manufactuers often quote 100k times with some saying up to 1,00,000 times now. When a bit reaches this point you will simply not be able to erase it. Think about this for a minute.... Say you have 1 file that is erased and re-copied to the drive everyday. If each bit lasts 100,000 write cycles you could theroetically copy your file once a day, everyday, for 273 years before those bits reached their end of life.
Personally I would go for the flash drive. More reliable and much more portable. You can get flash drives upwards of 2GB now. And a 256MB flash drive is still cheaper than a 100MB or even 250MB Zip drive.
