Zine
digital_exhaust
[H]ard|DCer of the Month - May 2008
Can't connect the damn thing to my computer, it just shows up as a camera.
How do I transfer music over to it? It won't let me copy and paste anything, and when I use WMP (which is what the manual told me to do) it doesn't recognize it...
Any ideas?
Thanks!
I'm not sure about the Zine, but try looking for a USB connectivity setting in the phone. Set it to something along the lines of file/picture transfer or media sync, and it should work. You probably have to unplug and replug the USB cord each time you set it to something different.
You have to install the motorolla phone tools that came on a cd. after then you have to connect the phone and change the connections setting on the phone for usb modem connection.
My wife has the phone... not the easiest to connect however once running the mototools will allow you to do what you are looking for.
Ah...MPT, I'm familiar with it, it's not a free utility is it?
I had a copy years ago when I had my Razr, but it's long gone....
Um... yeah, look in the box:rolleyes:
It's my kids phone, and I never thought to look.... thanks for that, appreciate it, and yes, I am an idiot....
