ZFS with intel integrated card?
ToddW2
Anyone use this (INTEL) RMS25JB080 with ZFS?
Trying to figure out which adapter will work, this is 2308 based so I think I could use it...
Does the controller support JBOD mode? The spec sheet says it should but you never know. With ZFS you don't want the controller getting in the way.
I'm aware of what I 'need' for ZFS, I'm wondering about this specific item. If I knew what it did, and how it worked I wouldn't have posted asking the question ;)
I believe since it's LSI 2308 based it can be run in JBOD / IT mode, but I'm asking here for clarification prior to buying it.
I have used it with ZOL. Works fine and performs well.
But, there is a big gotcha:
It brings up the drives asynchronously. On the Ubuntu server I was running on that machine, I needed scripting to wait for the drives to become available before starting the ZFS pool in the bootup stage. Basically, I added a script to the mountall startup script to wait for udev to present the drives. Example script is available in the ZOL documentation.
The board I was using was an intel s2600cp4. Maybe other boards have different BIOS systems that do not have this problem. Anyway, mitigating the issue was easy enough.
