Hello,
Long story made short ... I had two drives in a 4 disk raidz that started having problems. The pool was working fine, all my data was still accessible. I decided I would replace one, scrub, let it replace the disk, etc than replace the other. Well, after offline-ing one drive and turning off the system so I could physically replace it, it kept rebooting with a ZFS Panic error. I went into single user mode, edited rc.local to stop ZFS from booting, and able to make a few changes. So anytime I tried to do anything ZFS related, it would Panic and reboot. I figured it was the other bad drive (/dev/ad18) so I removed that drive and now I can boot with ZFS enabled, check zpool status, etc.
So here is my dilemma ...
I have a pool which has one drive unavailable (/dev/ad18) and one drive that is offline (/dev/ad12). I can not online the drive because the state is UNAVAIL. I have a feeling if I can somehow online this drive, I can get things working.... so my question is, is there anyway I can possibly online this drive? reconnecting /dev/ad18 will not work because if I do, any command I run will just cause the system to panic and reboot.
Is there someway to edit the zdb to online the drive that is offline?
is there someway to "copy" /dev/ad18 to another drive and make ZFS think its the original drive, just without errors, and see if I can replace that drive to bring that back online?
Any help will be greatly appreciated!! If you need any additional information, commands run, etc... please let me know
