- Aug 4, 2004
With luck, I'll be picking up a couple more 240GB SSD drives to build a 4 disk RAIDZ pool to move my home VMs to. Any gotchas or worries to plan for? The main VMs running in my home lab are...
1. Untangle box
2. Windows 7 DVR (was SageTV, trying WMC... but they record to a iSCSI share on a spinning disk pool)
3. Torrent/Usnet box (downloads to shared storage on a spinning disk pool)
4. Server 2012 Essentials (backs currently go to storage on a DroboPro via iSCSI)
5. Plex server (pulling files from the shared storage pool)
I've got a couple other systems for ripping disks and running handbrake and plan on spinning more test systems up soon, but those are the "always on" ones. I think I have them pretty well configured to minimize any SSD usage on the new pool.
The storage server and ESXi server is on an APC 1400 UPS with sync writes disabled for the spinning disk pool. My plan is to enable sync writes for the SSD pool since the IOPS are a lot higher. I haven't decided if I can squeeze everything into 480GB and run as a stripped mirror, or just go for the extra space and do RAIDZ, but either way the performance should be better than my 6-disk stripped mirror of spinning disks.
1. Untangle box
