My current setup:
* Supermicro SC846E1 - LSI SASX36 expander, 24 drive bays
* Supermicro X8DTN+-F motherboard
* Supermicro AOC-USAS-L8i HBA (LSI 1068E) - IT mode (JBOD)
* Solaris 10 update 9 (09/10) OS
* Mix of SATA HDDs in four different ZFS raidz2's
I recently purchased a 3 TB drive (Hitachi Deskstar 7K3000) that I want to be able to use to its full capacity. However only 2 TB is recognized.
23. c1t29d0 <ATA-Hitachi HDS72303-A3B0-2.00TB>
/pci@0,0/pci8086,3410@9/pci15d9,a580@0/sd@1d,0
From research it looks like the culprit is the LSI 1068E chipset which does not support drives over 2 TB. Therefore I am looking at the AOC-USAS2-L8e card (SAS2008 chipset) which I believe should be supported by the mpt_sas module. "man mpt_sas" on my system suggests that it's there: The mpt_sas host bus adapter driver is a nexus driver that supports the LSI SAS200x/2108 series of chips...
It is my hope that I can simply replace the HBA, without changing anything else in my setup, and: (a) it will see all of my old zfs pools on existing drives, and (b) it will recognize the new 3 TB drive. [Note: I have no data on the 3 TB drive that I care about, so you can assume I will be reformatting it once its full capacity is recognized.]
Can anyone speculate or confirm whether this plan is likely to work? Thanks in advance!
