ZFS Pool Upgrade
N Bates
After updating omniosce from r101524 to r101526 and napp-it from 18.01 feb 02/2018 to 18/01 arp 02/2018 I am getting the below, should I upgrade both my pools? rpool and my NAS pool? which version will this become after the upgrade? I beleive I am on version 5000 currently.
zpool status
pool: NASS
state: ONLINE
status: Some supported features are not enabled on the pool. The pool can
still be used, but some features are unavailable.
action: Enable all features using 'zpool upgrade'. Once this is done,
the pool may no longer be accessible by software that does not support
the features. See zpool-features(5) for details.
scan: resilvered 11.5K in 0h0m with 0 errors on Sun May 13 14:21:01 2018
config:
Pool: NASS:
Feature Value
pool version - (5000, Feature Flags)
zfs version 5
feature@zpool_checkpoint disabled
feature@spacemap_v2 disabled
feature@spacemap_histogram active
feature@skein enabled
feature@sha512 enabled
feature@obsolete_counts disabled
feature@multi_vdev_crash_dump enabled
feature@lz4_compress active
feature@large_blocks enabled
feature@hole_birth active
feature@filesystem_limits enabled
feature@extensible_dataset enabled
feature@enabled_txg active
feature@empty_bpobj active
feature@embedded_data active
feature@edonr enabled
feature@device_removal disabled
feature@bookmarks enabled
feature@async_destroy enabled
Pool: rpool:
Feature Value
zfs version 5
Thank you.
There are new incompatible but very nice features like systemwide checkpoints and vdev remove
that are available after a pool update (version remains 5000 but with new features).
If you update and use the new features this pool will be incompatible/not importable on a former OmniOS/OI or other Open-ZFS
Thank you _Gea for all your help, I am currently running r101526 is it better to go to the lts version r101522 until support for this expires or should I just continue upgrading to the new stable versions?
If you need a release that remains the same for years but with critical fixes, use LTS.
If you like newer ZFS features, use latest stable.
