Is it expected that ZFS/Nexenta performance will be absolutely dire on SmartArray P400 hardware?
For example P400 card, mirrored pair of 5400rpm SATA discs, (for testing only before purchasing faster discs) writing at only 2.9mb/s (expect at least 40mb/s):
We've tried changing MAX/MIN PENDING, and disabling the write cache flush. Neither improved performance.
Is there anything we need to do to make this card ZFS friendly? Or are these smart cards totally unsuitable for ZFS?
(As an aside this system is intended to replace another SmartArray system - 6400/MSA20 which also has poor performance - 30mb/s absolute peak from a 9 disk raidz2 - random writes are more in the order of 5-10mb/s...)
Edit: I should add that the server proc/mem is vastly over specced - quad core or dual quad and at least 8gb RAM - we've tested with upto 32GB)
root@nex385:/volumes# dd if=/dev/zero of=/volumes/v1/tempfile bs=1M count=1000
1000+0 records in
1000+0 records out
1048576000 bytes (1.0 GB) copied, 363.651 seconds, 2.9 MB/s
