You would have to tell me more about your ZFS server. What OS? Is it 64-bit? How much memory? How much kernel memory that ZFS can use?
In some cases as i've noticed, systems with 4GB would only assign 1GB or so for ZFS by default, which is too little and gets memory starved. But i've yet to do more thorough research on ZFS performance in general. For now i'm focusing on issues which persist with 4K sector drives.
So the fact that you have low performance may not only have to do with 4K sectors; first assure that ZFS has enough memory. 3GB dedicated to ZFS is a reasonable start; but that won't happen with default 4GiB RAM on FreeBSD; you would have to tune the loader.conf to do so, by adding:
vm.kmem_size="3g"
vm.kmem_size_max="3g"
vfs.zfs.arc_max="2g"
Also see: http://wiki.freebsd.org/ZFSTuningGuide
vm.kmem_size="3g"
