brutalizer
- Oct 23, 2010
Aesma, why 19 disks? Is it a "magic" number for raidz3?
ZFS is a professional filesystem, such considerations are not a priority. If you lose too many drives you lose everything anyway.
As a professional filesystem they should realize that a sync/silver priority value as a property for a ZFS dataset (analogous to the fsck priority in /etc/fstab) would be a useful feature.
Can you explain the benefit ? If you're using the drives in production, whatever is being resilvered, your performance will be affected.
I would use raidz3 for better safety. And with 20ish disks, I would do two raidz3 vdevs of 11 disks each, which means 22 disks in total.
So if you have an additional 6 disks in the PC case you can have 22 disks in total for two raidz3 vdevs. And I would make sure to use disks like this:
vdev 1:
JBOD case holds 8 disks + 3 in the PC case
vdev 2:
This way, if you loose your PC somehow, you can still start up the JBOD case, all data are intact.
Compare to this setup:
vdev 1:
-JBOD case holds 11 disks.
vdev 2:
-JBOD case holds 5 disks and 6 disks in the PC case.
In this last setup, if you loose your PC (it gets stolen) you have lost all your ZFS data. Because you can not boot up the JBOD case, because vdev 2 is corrupt as it only contains 5 disks. So, make sure the parity disks are in the PC case (distribute them to the PC case).
