mmmmmdonuts
- Oct 7, 2009
My all in one SAN/NAS is starting to run out of room and I am going to need to expand very soon. I am at 72% currently on a RAID-Z2, with 6, 2TB Samsung HDD's. Currently I have one IBM-1015 where the drives are connected. My backup solution currently is JBOD with 4, 2TB drives. The current purpose is mostly media files and a few datastores over NFS (not more than 100GB currently).
I am trying to figure out what the cheapest option in the long run will be to expand storage. My original intent when I originally went with RAID-Z2 was to upgrade to 4TB drives and use the original 2TB drives as backup. (Raid + current backup) With the price of 4TB drives still being ridiculous, do you think it’s worth it to buy 6, 3TB drives or would a better solution be to redo the pool and go with an 8 drive RAID-Z2, with 2 more additional 2TB drives? I know this is cheaper now but not necessarily in the future when 8 drives need to be purchased to expand storage.
I also am thinking about adding 2 SSDs in a RAID-1 configuration and using them to serve up my local datastores because performance is not the greatest. I know I can disable NFS syncs, but with 4 VMs reading on the drive all at once it helps a little bit but performance still isn’t the greatest, and I plan on adding more VM’s in the future. I can also fit another IBM-1015 if needed in my MB.
I am trying to limit a budget to $1000 max but am flexible and am trying mostly to think about the future and planning. Any suggestions?
