ZFS disk errors
JWeavis
napp-it OI OpenIndiana appliance v. 0.500s nightly Jul.03.2011
Code:
Disks in use:
id	cap	pool	vdev	identify	state	if	busy	error	vendor	product	sn
c1t10d0	2.00 TB	jweavis	raidz	via dd	ONLINE	c1	configured	Error: S:0 H:0 T:0	ATA	SAMSUNG HD204UI	-
c1t1d0	2.00 TB	jweavis	raidz	via dd	ONLINE	c1	configured	Error: S:0 H:0 T:0	ATA	SAMSUNG HD204UI	-
c1t2d0	2.00 TB	jweavis	raidz	via dd	ONLINE	c1	configured	Error: S:0 H:0 T:0	ATA	SAMSUNG HD204UI	-
c1t4d0	2.00 TB	jweavis	raidz	via dd	ONLINE	c1	configured	Error: S:0 H:36 T:0	ATA	ST32000542AS	-
c1t8d0	64.02 GB	jweavis	cache	via dd	ONLINE	c1	configured	Error: S:0 H:0 T:0	ATA	OCZ VERTEX-TURBO	-
c2d0	37.02 GB	rpool	basic	via dd	ONLINE	-	-	Error: S:0 H:0 T:0	-	-	WD-WMAKH1165430
c2d1	2.00 TB	jweavis	raidz	via dd	ONLINE	-	-	Error: S:0 H:0 T:0	-	-	 	WD-WCAZA01
Disks not in use:
c1t3d0	2.00 TB	-	-	-	-	c1	configured	Error: S:0 H:36 T:0	ATA	ST32000542AS	-
c3t0d0	0.00 GB	-	-	-	-	-	-	Error: S:0 H:0 T:0	ATAPI	DVD A DH20A4P	-
Code:
 pool: jweavis
 state: ONLINE
 scan: scrub repaired 0 in 9h7m with 0 errors on Mon Jul 18 08:07:15 2011
config:
	NAME         STATE     READ WRITE CKSUM
	jweavis      ONLINE       0     0     0
	  raidz1-0   ONLINE       0     0     0
	    c1t1d0   ONLINE       0     0     0
	    c1t2d0   ONLINE       0     0     0
	    c1t10d0  ONLINE       0     0     0
	    c1t4d0   ONLINE       0     0     0
	    c2d1     ONLINE       0     0     0
	cache
	  c1t8d0     ONLINE       0     0     0
errors: No known data errors
About 2 weeks ago, c1t3d0 showed up as degraded, so it was replaced. I haven't removed it or found out how to "remove" it from the pool. Yesterday both the Seagate drives were at H:24
Is your question how to remove the old disk, if so zpool remove poolname /deviceid is the command to do so. In your case zpool remove jweavis /c1t3d0 should do the trick.
That was one of them, thank you, but:
Code:
cannot remove /c1t3d0: no such device in pool
The other was, why do I seem to have the Hard errors increasing on both the Seagate drives in the same increments?
