Retsam_Evals
- Apr 7, 2014
Case - Supermicro SC846E16-R1200B
Backplane - BPN-SAS2-846EL1
Motherboard - SuperMicro X9SRL-F
CPU - E5-1620 v2 3.7GHz 4c/8t
RAM - 6x8 GB sticks (8x8 planned and I can borrow some for testing if dual channel will be a bottle neck)
HBA - SAS9207-8i
Drives - currently 14 x 3 TB WD Green (Intellipark set to 5 min)
I also have a couple of Mellanox ConnectX MNPH29B-XTC NICs if any one is interested in some 10 gb/s testing.
I have never setup ZFS before but would like to figure out the best setup before committing data to the array and being stuck with it. I have been debating between 2 x 11 drive raidz3 or 4 x 6 drive raidz2 with 4 TB or larger drives. I decided that since I'm in not hurry, I may as well test different setups.
So what benchmarks are recommended?
What implementations of ZFS should I look at?
What configs would you all like to see numbers on?
Is there a script to test a bunch of configs instead on me testing manually?
Any recommended advice?
Does any ZFS version support hot spares yet?
HBA - SAS9207-8i
