- Nov 2, 2010
hardware 2x amd 6128HE
all of the vt-d and virtual stuff is enabled and working
48gb triple channel ddr3 i think it is 1333 speed
host has a adaptec 5405 with 2x10000rpm drives for host os (proxmox, overkill) and 2x500gb seagates for VM OS's)
all intel nics, i have 3 and only have 2 in use, 1 for host and one dedicated to the single vm that is running freenas
5x st3000dm001 on perc310 flashed IT PCI pass through
Raidz ZFS, tried with lz4 and with no compression maybe 1-3 MBs change
network does not seem to be the issue as i can open remote desktops and generate other traffic and it all seems fine.
freenas VM has access to 6 cores and 20gb ram
all gige network
getting about 33MBs write and read even on a local write say from host to ZFS
getting about 33MBs even if i do a copy from the raidz back to the raidz
if i do more then one read from the zfs the speed on each read halfs. so i get 2x reads at about 17MBs
i have a real raid5 array on a different server and i can pull and push 5x the traffic to it with out any issue. what am i doing wrong?
all gige network
