Zeroing in on a new case formy new build.
Discussion in 'Cases & Case Modding' started by DWD1961, Jan 4, 2020.
  1. DWD1961
    DWD1961 Limp Gawd
    251
    Nov 30, 2019
    The perfect case:
    --The smallest , functional, case I can get with 230MM fan support top and front, or top and side, or some combination, modded fan would be okay.
    --200MM fan would be ok.
    --ATX compatible
    --ATXPSU
    --Full sized video card
    --$150.00 or less. UPDATED
    I can't find any that support 230mm fans, but they actually should because the width is the same as a normal tower case.
