Zalman
ZenDragon
Just bought a dual core A64 3800, and I was just curious if my trusty old Zalman
CNPS6000-Cu will work with this new beast? This is my first A64 setup so Im not to familar with the the mounting support. Im sure it wont but it doesnt hurt to ask.
I have a huge 120mm fan blowin on the thing.
i dont think so, but id get a cnps 9500 though, that always works,
bhut yeh, wont fit
best bet is to get a new cooler, imo
yeah its time for a new hsf buddy, the stock hsf is pretty good without OCing. But if your OCing id recommend the new zalman cnps 9500 for air cooling
yeh i would go with an active cooling system
i highly recommend the Thermalright xp90 or xp90c. w/ a 92 mm fan
i run mine on a crappy fx53 clamhammer and get 43-46 idle temps and 50-55 load w/ ambient temps at around 25-30
