FOREWORD : The cooler is tightened as tight as possible. It was a hard job figuring out which holes to put the screws in,
because the guide on the zalman website says that no. 5 holes are for 8600GTS. That is not the case. You have to put 2 screws into hole 2 , and 2 into hole 1 to mount the cooler . Way to go ZALMAN, had me doing all sorts or Permutations and Combinations for 30mins .
Yesterday I put on the Zalman VF-900 on my card . Now I don't know whether to say job well done to Zalman, or be surprised at how good Palit cooling is
Used MX-2 , also put the RAM sinks . Will try to go for a higher overclock than PALiT cooling today .
Idle temps went down by 4C.
I did a 3min Furmark test on both .
PALiT cooler 100% - 60C
Zalman VF-900 Cu ( Connected to MB, spinning at 2560 RPM) - 57C .
This is the card (8600GTS) and cooler
