ZALMAN VF900 on a microfly?
cuber
just wondering if the vga cooler will fit (Zalman VF900) on my microfly case without getting in the way of the PSU or other components.
thanks
My 7900GT has about 4mm of clearance between the top of the card and the PSU. So as long as your VF900 doesn't extend more than 4-5mm over the top of your card, you should be fine.
I put one on a 7900GS and its fine, you just have to massage it in when sliding the mobo tray into the case.
