monoboogie
- Feb 20, 2007
I have a Zalamn Reserator v2 watercooling system hooked up to my overclocked Q6600 and to my 8800gt.
The reserator is known for its weak pump, and due to my placement, the tubing is quite long.
I was looking to add a booster water pump to aid in the flow.
Is it alright to add two pumps to a system? (I know its a newb question, but want to make sure its alright without ruining the pumps)
Also, if I add it right before the cpu block, can it be harmful beacuse the coolant wont have enought time to absorb the heat?
Thanks guys!
Thanks guys!
