Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Getting a new heatsink and fan but I'm not sure which to get, the zalman or the thermalright sp-94. Looking for something quiet but will be able to keep temps nice and low.
if your looking for a quick solution that requires little work to install/setup, get the zalman. the thermalright will perform a little better and can be just as quiet but youll need to remove the motherboard to install it and youll need to look for specific fans that have low noise.
while the Tr is a better HSF the zalman 7000's cool almost as good and even at max fan speeds are very quite!!! if you get the zalman get the alxu it cools as good (with in 2c at worst) as the cu and weights like half as much.
