So I bought one to put on my new Gigabyte S3. My other blocks are copper Swiftech parts. Since I bought my cooler along with some Coollaboratory liquid metal TIM a few months back, I forgot that you shouldn't use that stuff with aluminum. So anyway, I apply the paste to the northbridge and mount the cooler. I prepare some other stuff and I hear a plick
Grrrrrr. Well, I can cobble something together and make that work yet. Or not-
I see cracks, and a lil blackened oxidation where the contact piont was made. I honestly don't think that 2mins. of contact with the gallium in the Coollaboratories TIM would cause such cracks. But I may be wrong.
That was after 15mins. and having tried to clean off the surface with some acetone. The other tab on the oppisite side fell off just from handling it. Sorta acted like really cheap pot metal.
I guess I've learned my lesson. I shouldn't have saved $5 and just went with another Swiftech block in the first place.
Since I wanted to get it built before christmas, I was able to cobble something together with hardware store goods. Here's my brass block (ugly, but does the trick)
Rig so far
I just got my Swiftech block from newegg, but I'm debating on sending it back. Although it would look a lil better, this seems to work fine, is solid, and costs a lil bit less. I dread the idea of draining my system and removing a bunch of crap just to swap out the block.
Rig so far
